Hi people,
I'm trying to get this linksys wag54g router to work on my friends pc and it's driving me mad!!
The thing is i don't think it's the router at fault, but something on her pc. here's the situation:
usual connection : tiscali 2mb usb modem- dials up no problem and internet explorer works.
go through the routine of setting up the router- no access at all, not even to the router.(checked lan cable etc- all ok)
Boot into safe mode and no problems at all- router is set up and will connect and internet explorer loads up.
Boot back into ordinary windows and nothing again. (router still on and connected)
if i go to tools/ check internet connection (in ie6 i think it is) it says that http,https and ftp are not available- check your firewall.
I've tried disabling the firewall, restoring defaults and even disabling the router firewall- it still wont work!
Sorry for the long post but if anyone can help it would be much appreciated- i have clumps of hair torn out of me scalp!
regards,
Steve.
regards,
Steve.
