Connect3D ATI Radeon X1900 XT 512MB GDDR3 - BIOS??
8 Jun 2006
Hertfordshire
Hi all,
I may place an order for the above as it's in 'this week only' but its dual DVI and I can only see my BIOS with my NEC 20WGx2 if I have the VGA cable in..??
Is there another way round this, as we all know I can't overclock if I can't see the BIOS :D
Am I missing summit?
sorry ami misunderstanding something here, but with dvi u cant see the bios in the NEC 20wGX as i got that as well.
i,m using dvi on my screen as well.
sorry i,m bit confused and how long is the warrenty on these cards?
thanks
FC-PJA said:
You get 2 DVI to VGA convertors in the box so you'll be fine.
Thats the answer I was looking for....
Will order that tonight when I finish work then......(Tweakinfreak strolls off with a large spring in his step....!!)
Cheers..! :D
You might find you don't need it at all, the X8x0 series DVI bugs may no longer apply ;)
With my Fujitsu Siemens W19-1 an X8x0 doesn't even give a signal over DVI (and the port does work on other monitors, as does the W19-1 DVI on other cards), both manufacturers acknowledge the problem yet blame the incompatibility on the other :rolleyes:
guys
can someone explain please?
is it that you cant see the bios on this card with the nec or something?
