Hi, I need to connect 2 sites together which are 250m apart onto the same network. There is a lot of underground conduits which I can run cable through and also a low power electricity cabinet approximately in the middle of the run (125m distance) where I could boost the signals. I was just thinking of installing a network switch there plugged into the mains to boost the signals, providing 125m runs were not a problem.
What is the absolute maximum for ethernet cables?
Can anybody suggest an alternative solution (not too expensive). I can't really go down the wireless route as there are buildings in between the 2 sites and our radios that we have down there are struggling with range.
Thanks
Thanks
