- 21 Apr 2006
The first router has an ADSL modem integral, the second doesn’t but has a Ethernet port and the usual 4 LAN ports.
The question I would like to know is should I disable the DHCP Server on the second router because it runs perfectly both ways DHCP disabled or enabled, I know that 2 routers connected together LAN to LAN does require the second routers DHCP Server disabled.
Simple which is the correct protocol many thanks
