Most switches will automatically set the port used for the cable you use so it shouldn't matter what cable you connect them with. I've always used normal cables.
It depends on the switch. Some have an uplink port so you don't need a cross over cable and some are just autosensing. Try it with a normal cable first and if it doesn't work you need a cross over cable.
