Connecting 3 pin cpu fan to 4 pin cobbector on motherboard
8 Apr 2009
Manchester
Hi
The fan controler for my CPU fan became faulty so had to take it off and replace it and can remeber how it was connected.
I have a 4 pin connector on the motherboard and the fan controller from the CPU fan is a 3 pin, so I want tro know is which end pin do I miss out to connect it?
Do I miss 1 pin from the left and plug it in the remaing 3 or the other arount?
Thanks
Leave the blue wire unconnected that will allow the fan to run full speed.
Sure will - on the four pin male you will find that there is only one way you can connect the female connector.
