Connecting 360 to PC problems
18 Oct 2002
Kent
A friend is trying to play music off his PC on the Xbox360. He can connect to Live ok, but can't access his PC. I'm guessing it's a network / sharing problem, but he says he's 'shared' the music folders etc.
He connects his 360 to a Netgear wireless router via the ethernet cable provided and his PC wirelessly to the router. Unfortunately, he's lives too far to pop around and have a look......
Any ideas ?
I had a load of firewall issues before getting it to work correctly with Media Centre and Media Centre Connect. So fiddle with the firewall stuff until it gives in :)
yes, using media connect. Although on my setup I can play music from PC without media connect ( media connect just doesn't want to work on mine ).
He can't do anything.
I believe he's run the test, and is ok until it looks for computer and it can't find one !
I ahd a simialr problem and the media test wouldn't run and show the sharing as working.
However I found a topic on the xbox forum which suggests that you you ignore the tests, go into media and select the songand , hey presto it suddenly worked for me.
Also as a guide this is quite handy
http://forums.xbox.com/1076872/ShowPost.aspx
