connecting 970 gpu 8pin 6pin to psu
22 May 2012
Brixton
Hi Everyone,
I know that this might belong in the psu section but that doesn't get as much love as the gpu threads! I got some good advice on my last post and have just received a lovely EVGA ssc 970 acx 2.0 (from OC, obviously) to replace my 670 sli set-up (birthday present from the wife!)...
I'm having problems installing the new card. My psu (modular) has 4 x 6+2 pin connectors (2+2) but the EVGA has 8+6 connectors. My previous cards had 2x6 pin.
I've tried all combinations but the card powers up (fans start up) but then dies. The screen displays a 'DVI-I no signal' message.
Do I need a new PSU?
I'm sure it's a power issue but any advice would be welcome. I've tried both PCI lanes on my MOBO. I work unusual hours and really want this sorted asap, I'm willing to speak to someone who may help as well as check replies!
** Removed **
Thanks in advance - Ash
Monitor: VG278H
CPU: 2500k @4.5
MOBO: ASUS P8Z77-V
RAM: 8GB DDR3
PSU: Aerocool GT 700w (bronze)
KB: Corsair K90
Mouse: Corsair M90
Hi,
You can only sell in the Members Market and you don't qualify for access yet.
Cheers
Surveyor
Hi,
Have you connected the power cables correctly?
You use a 6+2 from the PSU to make the 8 pin connector and the 6 pin part of a 6+2 for the 6 pin connector leaving the extra 2 pins unconnected.
If it still doesn't work with the power cables correctly connected make sure you have the latest motherboard BIOS.
Thanks. I'll try it now and report back in a few minutes. Would it make a difference if i boot with the hdmi or dvi-i?
I have 4 sets of 6+2 (2 cables with 2x 6+2's at the end) from my psu. I have tried both with 1 6+2 into the 8 pin on the gpu and the 2nd using the 6 into 6.
It boots and the fans spin but then dies. Just noticed the 'boot device led' flashes red on the mobo. Both dvi and hdmi are connected.
How would i upgrade my mobo bios without a screen?
I must sound like a noob...I really appreciate your input.
Ash
Ash
Old GFX card if you have one or onboard GFX if the the mobo has it.
Looking at the product page for the P8Z77-V it looks like it has DVI and VGA ports.
I've obviously missed something as my old cards are also not outputting a signal. I'm giving up and trying tomorrow.
Thank you for the input :)
Mods: close thread
