Connecting a GTX 770 to power supply
28 Apr 2014
Hi, what am I missing here?
I have connected the PCIe 6pin cable to the 6pin slot on the GPU but I get a message at boot up "Please power down and connect the PCIe power cables for this graphic card".
I have a 500W PSU and my old graphics card (Radeon 1950XTX) is working fine on the 6pin PCIe connection
:confused:
PS: my system is an i7-4770k & 1 SSD, H60 cooler and no other devices so would have though the 500W supply is enough.
You can get adapters that convert 2 4 pin molexs into a PCIe adapter. There may be one in the GPU box.
Personally I would strongly advise you to invest in a better PSU.
ok good. Yeah i might just buy a decent PSU. Any thoughts on the correct PSU to buy. I would like a modular one as I have an mATX case
If you are going to stick with a single card then a good quality 500 - 650W will be ample. 750W and over if you want to go with a future multicard setup.
YOUR BASKET
1 x EVGA SuperNova G2 750W '80 Plus Gold' Modular Power Supply £89.99
1 x SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black £79.99
1 x Seasonic M12II EVO Edition 750W '80 Plus Bronze' Fully Modular Power Supply £79.99
Total : £264.97 (includes shipping : £12.50).
Anyone of the above would be fine. Just double check the dimensions to make sure that it will fit in you case.
