Connecting a HDTV via VGA
21 Oct 2005
Edinburgh
Right,
VGA cable arrived this morning, HDTV hooked up although I'm stumped as to what settings I should use.
I basically want to output the same picture on my HDTV as is on my monitor although the native res of both is different, and it seems to only allow my HDTV as an extension of my desktop - if you know what I mean. I want to run my monitor @ 1680x1050 and my HDTV @ 1360x768 (I understand 1366x768 isn't possible).
I've downloaded powerstrip - good move? What settings would you recommend?
TIA :)
