Hi
I've got a D-Link DIR-615 as part of my package from Virgin Media. As you probably know this has wifi G and N capability.
First of all the wired connection works fine with my desktop and laptop. Secondly, I can connect to the router via wifi on my laptop with no problem.
My problem comes when trying to connecting my Nokia N96 and N95 via wifi. My phone can pick up the signal, when I try to connect to it I get the usual password prompt. After entering the password though it brings up the message 'No WLAN Network Found'.
Does anyone have any ideas on why this problem is occuring or if someone has been in the same boat as me and found a solution? Just for clarity, I have made sure my router is transmitting a G signal rather than N only.
thanks in advance
Mike
thanks in advance
Mike
