It depends how you connect them.
If you just connect a switch port on both, you should disable DHCP on one and make sure both don't have the same IP (while not being in different subnets).
If you connect one to the other's WAN port, you'd need different subnets, DHCP on both, two lots of NAT and a whole world of hell follows.
