connecting ipod to stereo
23 May 2006
Blythe
I've connected my ipod to a denon hifi system by the red and white cables (phono or something I forget) but the problem is that everything is really really bassy and you can't tell what is being sung or anything its a musical mess. My friend had the same problem with a bose system aswell, is this a common problem and can it be fixed? I've messed with the EQ on both the ipod and the amp but to no avail.
Help please
Cheers
Collisster
I think the problem is because you're using the ipod microphone output rather than a dedicated line out.
You have to boost the amp more than normal and it all sounds, as you said, a musical mess.
I've not got round to it myself but you need to get a dock with a line out then the problem is solved.
