Hi guys,
I have an old sony micro system which has a cd adn mini disc player...anyhow on the back i have a TAPE IN input. Would i be correct in thinking that using a 3.5mm jack to rca plusg would do the job?? ie connect my ipod with the 3.5mm jack and plug the rca plugs into the tape in input??.
Just a bit concerned if i will cause any long term damage to the speakers or the ipod itself ie dont want that buzzing noise you get sometimes if you incorrectly connect equipment up.
TIA
TIA
