Hi all
got quite a tricky one really i have just bought a 40" LCD and a 360 which is rather nice. but on the other hand pc is not being used. My pc has 7.1 gigaworks and a X-FI Elite Pro soundcard with breakout box.
So i had a little idea with the help of mightynimrod that is . so it is can i connect my lcd and 360 and pc to the gigaworks in an all in one setup by using the breakout box...
the breakout box has.
Optical in and out _ so i would you's that for the 360?
And then which one of these would i use for the LCD
AUX IN LEFT AND PHONO IN RIGHT
Or SPDIF IN and SPDIF OUT?
Then the pc would just connect to it just like it is now no changing there. the only thing i duno how i would change the sound source to what i wont it to be on any idea's??
Thanks
XD-3
Thanks
XD-3
