Connecting Lian Li 140 Infinity fans to control unit.
21 Apr 2010
Looking for some advice am going to kit out my Lian Li Evo XL with 9 140 and 1 120. The question is
how do I connect these to the control unit? The connections look different.
The Infinity series have their own L Connect module. It comes in the 3 pack of fans. The 3 pack also has a connector with a single PROPRIETARY plug to go into the module from the bank of fans.
The single packs come with a connector with 2 cables. A standard 4 pin PWM and standard 3 pin ARGB. This lets you use any of your banks of fans on a standard motherboard/other controller headers. This connector will not plug into the L Connect Module.
The single and twin cable connectors are interchangeable between different size fans AND fans that came in 3 pacm or single packs. If you buy 3 x triple pacls of 140s and a single pack of a 120 then you will end up with 3 x single cable connectors and 1 x twin cable connectors. This will allow you the opportunity to connect 3 banks of fans to the L connect module. The module supports a max of 4 banks so if you want 4 banks then you'll need an extra single cable connector.
Lian Li Uni Fan SL Infinity to Lian Li 7 Pin Connector Adapter Cable is the cable that I need to connect the 140mm Fans to the unit. This cable is only supplied with 120mm fans.​
Are you sure you want to use 140s? The 120s perform better and you would also get the cables and module you want in the 3 pack.
