Connecting monitors?
16 Apr 2015
Hi, ok hands up this is probably a stupid question, but:
had a new 980ti card fitted by a computer shop, and they had it up and running ok, displayed fine. Have got the pc home, and now i dont get any output from the card.
Have plugged in 2 dell 2715h, using the dp/mini dp cable supplied by dell with the monitors. each cable plugs the DP jack into the card, and the mini dp end into the monitor. I checked the obvious, all ends are secure and the mini dp is in the right input on the monitor!
Any ideas? would a different cable make a difference or is this something more basic (im assumiing ive probably done something dumb here)
any ideas much appreciated!
