Connecting my Asus Aura Motherboard to Bitfenix Enso Mesh RGB controller?
7 Dec 2002
UK
I have an Asus Aura motherboard with 3 pin ARGB header in a Bitfenix Enso Mesh which states it's Aura Sync compatible. There are however no instructions with it on connecting it up.
The Controller has a cable coming off the front panel that goes into the RGB controller, it also has an empty female ARGB 3 pin connector hanging there.
However there is also some other type of 3-pin connector which is also empty.
My confusion comes from the fact that none of this is labelled & the cable to connect from the motherboard to the controller is a Y shaped cable & has both plugs on it.
Where do I connect it without something going pop?
Just realised that the RGB front panel lighting can be disconnected entirely from the controller & leaves a female Aura connector free, i presume I can simply connect this to the RGB header & ignore the case supplied RGB controller entirely?
Hi.. you can solve? I had the same problem,... in the official page says "long press buton" but is not works..
