Hi, I've realised my audio know-how is out of date with present tech and I need some help with understanding what my options are. I have an old NAD stereo amp with a pair of Tannoy M2 speakers. I'm happy with the sound I get from this setup but the NAD amp is on the blink and so I'm looking at getting a new amp, but I want to take into consideration that things have moved on from plugging the amp into the headphone jack of a TV, which is how I currently switch between the TV speakers and my amp/speakers set up. This has always been a pain as it means reaching behind the TV with a 3.5mm cable every time.
TVs now seem to have a smarter way of dealing with an external amp/speakers setup. There's this thing called HDMI ARC, which I assume is what you use to connect to an AV receiver. My question is if I bought a modern stereo amp, would I be able to connect my TV to amp in this way? Is there anything else I need to consider? Second and perhaps most important question is what amp would you recommend to pair with my TV and Tannoys for best sound quality, bearing in mind I probably have a budget of around £200 but don't mind buying second hand? If that's too stingy and I need to be spending more to get the solution I need then fair enough.
