Connecting PC
27 Mar 2016
Bristolian living in Swindon
Hi all
This post may be in the wrong section...
I want to link my PC to my TV as i dont have a monitor until next payday, Do i only need a HDMI cable to do so... As i have a Blue adapter cable but its to small for the size on my PC, do they come in different sizes
Thank you
Hi
Yes if your pc has a HDMI output then just get yourself a HDMI cable and plug it into your tv its simple as that:)
What pc do you have ? model no ect
As long as you have an hdmi output on your pc then you're fine to just plug that into your TV and set the correct resolution. You may need to change your audio output to hdmi in playback devices if you want sound out of the TV . Job done.
