Connecting PS3 to DVI monitor or new LCD screen?
7 Mar 2005
The Voice Of Football
As above really. Just got a PS3 and want to put it in my home office as arguments will ensue about the missus wanting to watch placeinanidealhomeinteriorsoaprubbish show rather than me having pro evo fests.
So, the options I have are:
Buy a small LCD screen for the home office. Max budget £200
Or
Find some way to connect my PS3 to the above screen. Native res is 1280x1024. I have seen some boxes on the bay that claim to do the trick but can anyone provide me with a definitive list of what I need to get it connected as the sellers are all HK/China based and don't readily answer questions and if they do it's usuallly 'Yes do it connect Playstation monitor nice'
Cheers
think there is a asus 24" with hdmi for full 1080p on offer, a little over £200 budget but would be well worth it
edit sorry acer http://www.overclockers.co.uk/showproduct.php?prodid=MO-035-AC £260+ if your budget cant stretch then just get a dvi to hmdi cable or converter? you know you want the acer, sellyou current lcd for £60+ and theres your budget sorted, use either dvi or vga for pc and the hdmi for the ps3
