Connecting PS3 to Hyundai L90D vs New LCD screen
7 Mar 2005
The Voice Of Football
As above really. Just got a PS3 and want to put it in my home office as arguments will ensue about the missus wanting to watch placeinanidealhomeinteriorsoaprubbish show rather than me having pro evo fests.
So, the options I have are:
Buy a small LCD screen for the home office. Max budget £200
Or
Find some way to connect my PS3 to the above screen. Native res is 1280x1024. I have seen some boxes on the bay that claim to do the trick but can anyone provide me with a definitive list of what I need to get it connected as the sellers are all HK/China based and don't readily answer questions and if they do it's usuallly 'Yes do it connect Playstation monitor nice'
Cheers
For a good picture, I would think the only way to connect ps3 to the L90D would be via the hdfury (hdmi->vga). So options would maybe be a cheap small LCD Tv and use rgb scart (or if one has dvi which supports hdcp - use a hdmi -> dvi cable). or splash out on a medium size samsung tv/monitor with hdmi.
Cheers for that. Am now torn between buying a new 24 inch sammy LCD monitor to use on the PC and PS3 or to get a 24 inch LCD telly. Telly is obviously more expensive but would have more usese....but wouldn't be 1080p
That hdfury thing looks a bit pricey, the ones on the bay are lots cheaper
