Connecting ps4 / pc through same DVI?
13 Jan 2012
United Kingdom
I only have one DVI port on my monitor, is their some splitter type device i could use because disconnecting wires is becoming annoying. the only alternative is using a displayport for my ps4 but i dont know what image quality will be like on that
will displayport be as good as HDMI or DVI though? i thought it was inferior, also i have a 1920x1200 monitor and not sure if it supports that
in dvi win 8.1, did some research and read its something to do with a rounding issue for some monitors. for example on bf4 1920x1200 i can only enable this at 59.97hz but 1080 i can do at 60hz
yeah my acer monitor used to display @ 59.94hz i think its quite common thing :)
you could try doing a custom resolution and try setting hz that way but i doubt you would notice any difference anyway.
