Connecting sub to amp
24 Jul 2003
floating down the Liffey
I currently have a pair of Mission M72's hooked up to a NAD 315BEE, which I'm very happy with.
In the future I might look at getting a sub to go with them, however, when buying the amp I was on a budget and didn't plan for the possibility of a sub!
What is the best/easiest way to connect a sub, such as a BK Gemini, to this amplifier?
Thanks
You haven't got a pre-amp output on your amp, so the only option will be to connect via the speaker terminals as the 'high level' input
It seems the BK Gemini does have a high level input.
From what I've read, a gemini is probably the best budget option as far as subs go?
i'm just running a headphone splitter from my pc then connecting them both to the pc via that. That's how i'm doing it now until i get my AV receiver anyways
