Connecting T7900's to an X-Fi Music
27 Jun 2006
Hello,
Having a bit of trouble connecting these two up. The speakers came with two types of lead which plug into the back of the main base unit and then leave the other end of leads to plug into the soundcard.
One set of leads has 3 cables (to go into the soundcard) and the other has 4. I'm assuming the more speakers you use, the more 'slots' you are required to fill in order to get them working. For now I'm only using the central unit, a left and right speaker and the centralized one that sits on top of the monitor - meaning that 4 speakers miss out, but oh well.
Unfortunately there are no markers on the back of the soundcard so I'm left with 4 slots and 3 or 4 colour-coded cables depending on which lead I use.
These colours are Black, Tangerine, Grey and Green and Black, Green and Tangerine on the 4 cable and 3 cable leads respectively.
I've had a real good play about with different combinations of both leads and colours and I'm getting nowhere. Does anyone have any idea of where way they should be put in?
I've used headphones for so long and they have simply plugged into the 2nd from right hand slot - this however is a bit more challenging for me.
Would appreciate any guidance, I'll continue to look around for solutions.
