I am trying to connect my laptop to dual monitors so that I can work more efficiently. Setup as follows:
Lenovo 300e 2nd Gen Notebook Type 81M9 running Windows 10 Pro 64
Lenovo ThinkPad USB-C Dock Gen2
HP ProDisplay P232 x2
The Dock is working, bios fully updated etc. and is charging the laptop via USB-C connection. The Ethernet cable connected to the Dock is also supplying a wired internet connection.
The problem is that I cannot seem to get the display to show up on the external monitors. I have tried to extend, duplicate, change resolution etc. but in display settings the monitors cannot even be detected.
Monitors are connected to the dock via DP cable.
I have been in touch with Lenovo and been through the usual troubleshooting to no avail. Lenovo are unable to confirm whether the laptop is compatible with the dock or not.
I wondered whether anybody has experienced anything similar or whether there is anything else that anybody can recommend that I try?
Thanks
Thanks
