Connecting to a remote X server
9 Mar 2004
York
Hey guys,
How would I go about connecting to a remote x server that is at a specified address. I have ssh access too if that helps matters. I'm struggling to find any information on how to go about it. I think it should be possible because the uni uses exceed to connect to the server, it's just a matter of knowing what I'm doing!
Cheers anyone
Joe
Cant you just do:
Code:
export DISPLAY=remote.x.host:0.0
The remote X server would need to be setup to allow non-local connections though. Or am I way off what you're trying to do?
I'm not really sure, if possible I would like to open a window within my local X session with the remote X session.
I tried X :1 -query host.domain
but that didn't seem to do the trick. It started an xserver on display 1, but it was just the hatched background and X cursor
what about ssh -X username@host or ssh -Y username@host ? Assuming you're going linux - linux the display variable should be handled automagically by openssh.
Yep that seems to have done it. It doesn't create a new window with X in, but it does allow me to spawn X windows on my server, which is sufficient for my needs.
Thanks
