Hello there
Well, normally to connect through the internet on my desktop i use ICS and connect through my EEE pc and both are using Windows XP
All was working fine untill this afternoon when i tried to install the Windows 7 x64 RC on my Desktop.
Started the process and got this message:
Didn't know what to do so cancelled and decided to come on here to ask for help. Since getting that message I haven't been able to connect to the internet at all
When i use my normal method i just get Limited or no connectivity. Decided to plug my computer straight into router with ethernet cable and got the same problem.
One more thing, i can still connect to the internet wirelessly on my EEE which leads me to beleive that the problem lies on my desktop
Would anybody be able to help me solve my problem and help me get back onto the internet.
Thanks in advance.
Chris
When i use my normal method i just get Limited or no connectivity. Decided to plug my computer straight into router with ethernet cable and got the same problem.One more thing, i can still connect to the internet wirelessly on my EEE which leads me to beleive that the problem lies on my desktop
Thanks in advance.
Chris
