Connecting TV to PC
Look at the back of the TV. DVI or VGA is great. A Mini-Din will be S-Video. A Single yellow phono is Composite. All easy to do with your graphics card and some simple cables. (Listed in quality order)
The cables can be found in electronics stores. 1m, 3m, 5m, 10m etc.
A SCART connector on the TV can also be used as you can get leads which are SCART to S-Video.
You probally have some kind of fancy splitter cable that came with your video card. But if you can't find it, you can normall connect a S-Video to it. Again look at the baack for a mini-DIN.
The audio is a simple headphone jack to phonos lead from sound card to TV.
Post back with questions. Let us know what connectors are on the projector, the distance involved, and what your graphics card is. :)
I still need you to look round the back of the TV to check out the connectors. The graphics card is the easy bit. :D
