connecting two computers
4 Mar 2008
Guildford
hi,
just a quick question, is it possible for me to connect two pc's using just an ethernet cable (one that i would use to connect to the router), if so would i just plug each end of the cable into the ethernet port of each pc?
cheers
ali
if they're fairly modern PC's then yes it should work with a normal ethernet cable, otherwise you'd need a crossover cable
