Connecting VGA laptop to HDMI projector. Help
Unless the laptop outputs a digital signal via VGA (highly unlikely), that cable will not work. Typically, VGA is analogue only and HDMI is digital. There has to be a conversion from analogue to digital or vice versa. A cable alone will not do that.
You'll have to spend a little more and get a cable that includes a box which will contain the conversion hardware. This one should do the job. Has a lot of good user comments on the jungle site.
Hooked up the converter and I cant get the Laptop to display on the Projector. I hooked it up to my TV to try that and still nothing?
