- 8 Oct 2006
ok geting xbox 360 want to hook up to xbox live.
i have a router but it only has 1 ethernet port and my pc uses that. there is a spare ethernet port on my pc can i connect to that instead ???
i looked in manual and that sais you can connect your xbox to ethernet port on pc but that pc then connects to router/modem via usb
can i not do it all via ethernet ? so its router conencted to pc with ethernet, then ethernet comes out of back of pc and goes to xbox. was the instruction written assuming pc only has one ethernet port ?
