Connection Clips on Bosch AeroTwin Wiper Blades
29 Jun 2004
Do these blades come in two flavours? One which accomodates the regular hook type connection (bottom left), and one which accomodates all other connections?
If so, when you're buying online how do you know which connection type you'll get?
Yes, for everything else (not the hook type) they're called "multi-clip"
I had 2 brand new multi clip wipers sitting on a table as i didn't read the website clearly enough..
Are you 100% sure about that? Every rear window connector I've seen have been the same as the ones on the front.
E.g. My old Focus had hook connectors at the front, and a hook connector at the rear.
