Connection Drop
2 Feb 2012
Hi I've been having this problem for awhile now, where when I'm in a Skype call my connection will drop and Skype brings up a message saying that I've gone offline and even a red x comes up next to my network icon in the task bar.
I have looked under the event viewer and this is what it shows;
Intel(R) 82579V Gigabit Network Connection
Network link is disconnected.
And
The description for Event ID 27 from source e1iexpress cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
the message resource is present but the message is not found in the string/message table
I've reinstalled Skype, Network Drivers and even reinstalling Windows 8.1
Another issue I'm having iswell is my Ping on only my computer which is hard wired to the hub always keeps changing from 15 upto 34
