Basically, I've been through a few routers now, and after a while, the connection will just slow down, almost to a halt, I used to think it just cut out totally, but sometimes the pages do load. I've tried Netgear and Belkin routers with similar effects, second hand and new ones.
MSN Messenger strangely still works, although sometimes the connection does cut out entirely. So I have to reboot the Netgear router (wireless) and NTL, and the Belkin wireless access point anyway (on the same plug sockets).
Any idea what it is, already had the router replaced a few times as well as the NTL modem once, is it just a shabby connection?
Also, what's the best wireless router in terms of range, that isn't a Rangemax Netgear (because of the space-like lights coming from it!)
I am on NTL in Brighton, and have always used an old PC with a floppy distro of Linux called "Freesco". I have had this installed and setup from an empty PC to a fully working connection in less than 10 minutes. And once it is setup, you can forget all about it. Does an excellent job. I last had to touch the machine when the PSU fan started to fail (I did say it was an _old_ 486). That fan failiure was on 6-6-6 (freaky...) and the PC had been running uninterrupted for 380 days!!
