connection interupts?
19 Jul 2007
Bracknell, Berkshire
If it's not too BIG a question... What's the most common reason for CI's?
When gaming, my ping seems to jump about all over the place causing lag and connection interupts. It'll be fine for a bit (around 20) then it starts going mental!?!
I was using an actiontec router, but have now changed to a Netgear DG834G; no noticeable difference. MY ISP is UK Online.
Any pointers on what/where to check would be much appreciated. ;)
Not sure how to put it to be honest!?! In game, the ping and fps shoot up, and everything freezes. It comes up on-screen with connection interrupted! I guess it's to do with packet flow, but that is just a guess!?!
That could be one of a million things - you need to do some legwork to narrow down what's happening.
Your router will have an ADSL light (and ideally, a second light for the "internet connection") - does it change? Alternatively, there should be some status information within the router's web interface.
Does it happen every time you do something?
Hi tolien,
I'll have to come back to this one mate, as my comp died last night. :rolleyes: As soon as i get it working again, or replace the mobo, i'll come back to this. :(
Cheers for your help
Scott
