Hey bit of a dilemma here and not sure what is going to be the best option.
I current have my router which is upstairs (connected to the PC) which is connected to a extension from another extension (different room) which is connected to the main socket downstairs. I hope I have explained that clearly haha. The reason I'm thinking of sorting this out is because one of the extensions has snapped.
I'm thinking of maybe moving my router downstairs to the main telephone socket and getting power line adapters
or
Get a big cat5e cable and run it all the way upstairs and keep the router downstairs.
I've got other things to connect but I'm guessing I could just use a switch for those?
Just wondered if there is going to be much difference in terms of speed with those 2 options? and what adapters (if that is a good option) and Ethernet switches should I get? Router is a tp link if stuff is better to be paired. Also the connectivity is adsl+2
Thanks
Gazza
or
Thanks
Gazza
