- 4 Apr 2006
- Norwich
Hi all really hoping someone will have an idea about this,
basically for the last two weeks i have started having connection problems, most noticabley in games where my ping has gone very high and i frequently get connection interupted message.
i have changed no settings or software on my pc and use the same servers i have always used.
a friend told me to do a dos command "tracert" to trace the hops on my connection this showed that some of the hops were gettin up to 200ms connection times and also not alwaysd responding.
i phoned blueyonder who said they have no control over the hops in my connection but it seems strange that i have never had any problem but now for the last 2 weeks i have had theproblem constantly.
does anyone have any ideas what i can do? do you know any more information about how the provider can affect the hops in my connection? as half of the ip's on my list show as blueyonder.
thanks for any help
Loki
thanks for any help
Loki
