- 24 Jan 2003
- "Are we there yet?"
Hi, I've been trying to fix a friends computer, and now I've stripped out the malware, and a load of unnecessary programs, it's running at a decent speed.
The problem is, now I'm connecting it to the internet, it doesn't seem to be capable. I've got a cable, and a wifi adaptor, both working, and the hub is working fine as this pc is cabled, and the wifi works on other computers.
But everytime I try to connect with a cable, it says 'invalid ip address'. And if I try to connect with wifi, it runs the 'connecting' window for a minute then goes back to available networks 'Bthomehub2**** signal strength excellent' etc.
I've tried configuring the cable connection manually with a specific ip adress and using the hub control system on this pc to connect from both ends, but getting nowhere. the other pc is aware of the network, and tries to connect, but seems to be incompatible for some reason.
I've rebooted the hub, the pc, uninstalled and reinstalled the drivers, and run the wireless zero configuration program. I'm out of ideas, so could anyone please offer some advice?
Thanks
Thanks
