Connection taskbar icon gone screwy!
18 Oct 2002
UK
Anyone please help with this problem....
I'm been using a TP-LINK wireless adaptor with my sky broadband router with no probs at all. But today when I turned on my pc, the connection icon in the taskbar has a red x, but if I open it up, the connection is listed as ok and I have net access as normal...
If I open up network sharing centre it says I'm not connected to any networks...
I've not changed anything :confused:
Tried a system restore, but just get a blue screen crash. The only restore point is when a critcal update installed.
I assume you've already tried reconnecting and rebooted?
This may or may not fix it but try:
RUN> services.msc
Find "WLAN AutoConfig" and restart or stop/start the service. Also make sure it's set to automatically start.
RUN> services.msc
Tried all that, no joy. Thanks for the help though.
