- 14 Apr 2004
- UK
Well yesterday I finally went a Conroe system after years of being AMD only. I've built about 20+ AMD systems but only one Intel. You guys convinced me otherwise, with the aid of some off site reviews!
I'm also taking the opportunity to switch to PCI_Express with a 7900GTX from my current AMD64 3200 system which has a Geforce 6800GT. I'm hoping to see a big difference in 1280x1024 gaming on Call of Duty2! The scalability of the ATI X1900 XTX is supposed to really kick in on larger resolutions but as I'll be sticking with 1280x1024 for a few years to come, the quieter fan and slightly better performance at 1280x1024 of the 7900GTX won out. I'm looking forward to comparing some benchmarks from the old system to the new.
I went for:
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
OcUK GeForce 7900 GTX 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-038-OK)
Enermax Liberty 620W ELT620AWT ATX2.2 Modular SLI Compliant PSU (CA-024-EN)
Arctic Silver 5 Thermal Compound (3.5g) (AC-000-AC)
and
2 x Maxtor DiamondMax Plus 10 NCQ 250GB 6V250F0 SATA-II 16MB Cache Hard Drives which I want to run in RAID, although I've never done this before on an AMD board, never mind an Intel system! I'm not sure wether to go for RAID 0 for performance or RAID 1 for mirroring. I'd like to try performance first to see if it makes much difference loading games than one SATA HDD!
I take it you configure the RAID somehow before installing Windows XP?
I've ordered this system and its on its way, but what do you think? I'd like to be overclock it if possible by a reasonable and safe amount. I ordered the Artic Silver as I figured the OEM CPU wouldn't come with pads although I've never noticed much difference with the older Artic Silver in the past on the old AMD XP CPU's.
I also got convinced by another thread here about the AMD64's currently on offer so although my son is getting my current 939pin and 6800GT system I've ordered the AMD Athlon 64 4000+ San Diego (Socket 939) and Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) to replace the existing 3200.
Bad news is they ran out of stock of my new case the NZXT Lexa Classic Series Ultra light Aluminum Midtower so I had to get this from elsewhere and pay additional carriage but the Arctic Cooling Freezer 7 Pro is holding the order up!
Tell me I've done a good thing!
I went for:
and
. Is RAID 0 much quicker than just SATA? Anybody benchmarked it?.
