), but together with a smaller Process (e.g. 90nm or 65nm like the Conroe's) makes it even better for overclocking
NathanE said:Don't forget the Conroe is dual core whereas the Athlon XP was single coreThe TDP figures seem much more impressive when you consider that
125W TDP!!!, thats almost up to the 130W of the top dual core P4's.Corasik said:Sure AMD 'Claim' that intel only use a typical TDP to measure power use, but several tech sites have uses a 'plug in power meter' to measure the total power of AMD64, Pentium 4, and Conroe systems, and the Conroe's are doing great for their power draw. TDP is really a measurement that is used for heatsink designers, and isnt quite the same as how many watts of electic used by the chip.
No matter how they spin it, the Core 2 systems, with similar amounts of ram, and GPU's seem to be a good 35W less power draw than AMD64's, and dont even mention the heavy power draw of AMD FX62 systems. That chip is the new Prescott125W TDP!!!, thats almost up to the 130W of the top dual core P4's.
AMD's '65W Energy Efficient' x2 3800 seems to be less performance/watt than the Core 2's, and is bearly more power efficent than a Core 2 X6800 system.
