I recently swapped my Gigabyte GA-P35C-DS3R for an Asus P5Q-Pro, but am having some trouble overclocking.
Spec:
E6750 (Conroe, E0, 6-8 multi, VID 1.350)
Asus P5Q-Pro (BIOS 2002)
4x1GB Geil PC2-6400 (4-4-4-12, 1.9-2.1v)
GTX280
Rest in sig.
The gigabyte board was able to take this setup to 3.2Ghz on all stock volts with RAM at 1.9v (+0.1v), stable. It could do 3.4 but would sometimes just fail to boot despite being stable once it had.
My aim was to get to 3.6 with this new board, and I have had it boot and game for a few mins at 3.6, but it was not prime (blend) stable. However, it was stable in prime with small FFT test. This made me think the RAM/NB was causing a problem. CPU temps never seemed to go over 50 deg at load.
The NB voltage requires a small bump to boot with 4 sticks (5-5-5-18) at CPU stock (1.20v thats +0.1v), and is prime blend/FFT stable. However, when increasing the FSB, seemingly by anything, the thing will fail a prime blend test within a few minutes, despite still being small FFT stable.
I've had the NB volts to 1.34v, which lets it run for a few more mins before failing the blend test again. Tried booting NB at 1.36v, and it bluescreened before I could get into windows. The DRAM volts I have tried at 1.9-2.02v with no success (at 5-5-5-18).
Can anyone help me here, i'm not sure what to try next besides taking out 2 sticks of RAM? It looks like the CPU is fine, but the NB/RAM is struggling here. I'm about to run a memtest too, though the RAM has been perfectly fine in the other mobo for a long time (didn't require any increase in NB volts either!).
Thanks in advance!
Spec:
GTX280
Rest in sig.
Thanks in advance!
