Hi,
does anyone know why the temp sensors on the newer Allendale chips (e4300 etc) give a different reading than Conroe chips?
I built my system using a Conroe e6300 and had three different apps that gave me the exact same readings, INTEL TAT, MBM5 with Core2 Duo plugin and Core Temp Beta 0.94.
Then when I swapped out the e6300-conroe for a e4300-allendale only Intel TAT gave me the proper reading, the other two apps started reading the CPu temps way too low.
Anyway I have now installed the e6300 and all the apps are working fine again, all giving the exact same temps.
Its just a small thing but it bugs me, does anyone have any technical info of the difference between the temps sensors?. As it stands, someone using an e4300 on an nVidia 650i chipset doesn't appear to be able to get an accurate reading (as TAT doesn't work on that chipset).
I still see some posts from people who are using e4300's and they are saying how wonderful the temps are, I guess they don't realise they are getting an incorrect reading?
There are some new processors from INTEL expected the next few months and I'm wondering if they are gonna have these same hard to read sensors?
apart from that I hope u are all having a fun Saturday night!
Im sure someone can explain better.
