Considerations in buying a 27"
18 Apr 2012
Good afternoon all.
As first, I'd like to congratulate you all for management and upgrading of this forum: your work is helpful and very good. I'm quite new to these matters, at the moment I'm using an old (pre 2000) Philips 17", so every change will result in a huge improvement.
I use to spend 12 hours per day in front of the monitor, from 1 to 2 feet of distance, to study, work, watch movies and play: then I'm thinking about a 27", that would help me a lot in the use of program such as AutoCad, Revit, 3DS etc, and that would make movies and games much more enjoyables. I still need to understand if a 16:10 is preferable to 16:9, or 120Hz is preferable to 60Hz.
Studying on the net (mainly on this forum) new models, I happily discovered new 3D monitors, and I'm wondering about buying one, but I have some doubts: first of all, my primary necessity is 2D, and in principle, a very good 2D is preferable to a mediocre 3D. My question is: how far is gone 3D technology for monitors? My lousy experience in that suggests that a good 3D environment needs a whole dedicated system, and it looks like that the main chance is to buy nVidia 3D Set, which has - among 27" compatibles monitors ( http://www.nvidia.com/object/3d-vision-system-requirements.html ) - only an Acer ( HN274HB ) and an Asus ( VG278H ). Personally, I've had negative experience with Acer CS, and I've read on this forum that Asus CS is not that good: in addition, Overclocker UK Asus review ( http://forums.overclockers.co.uk/showthread.php?t=18371830 ) strongly advices it as 3D monitor, but unadvices it as 2D monitor.
Then, maybe better to go back to a passive 3D monitor, unbound from GPU, and since I wear glasses it would be better, but still I don't know how good is 3D environment by a 3D passive monitor without compromitting 2D, that's for me is priority. It looks like there exist monitor of this kind ( LG DM2780D ), but is their 3D worth the price different with a similar if not better 2D monitor?
I'm quite confused, considering I'm planning to hold it for 6/8 years: I could be sorry by renouncing 3D for so much time, but I could be sorry too by spending quite the double for a mediocre 3D environment that I would not use, or, the worst, a good 3D and a not that good 2D.
Desktop PC I'm going to buy with it is a I7 2600 cpu with 8gb ddr3 ram and a nVidia GeForce GTX 560 Ti, but I'm still quite flexible about it and I've not a precise budget for monitors: I'd say around 300€ for a very good 2D, but I have no good ideas for 3D.
Thank you for your help.
Why Damage your eyes with 3D..In my book 2D is far better at this moment in time. For what you be doing I would say 2D is far better anyway.
Just my Honest opinion. We need our eyes.
I would say wait another two years before buying 3D, by then there will probably be better out there.
I prefer 16-10 so like you I'm waiting for someone to say which 16.10 is Good.
I have a 24" 16.10 DMG from here, but I can now see some colour through my B&W images in photoshop behind the image, so not sure if it's this monitor or graphics card.
Good Luck.
i really dont see the appeal to 3d gaming. i dont think ill ever do it.
if it does become popular ill look into it in the future but it will be years yet imo, by then monitors will have come leaps and bounds especially in a new tech like 3d.
If colour accuracy and viewing angles are important for you, make sure you go with an IPS screen.
If response time and refresh rate are your priority, go with a TN panel.
From the programs you listed, a high res IPS sounds like it would be the best fit.
