I don't really need to upgrade but I've had some money come through and my current pc has been on pretty much 24/7 for 10 years. It's no longer capable of holding a stable overclock. It's showing its age in gaming (but so am I). It's not compatible with windows 11.
What are the trends nowadays? AMD or Intel? I'm happy to move the graphics card over from my current build as I don't game above 1080p and the 1060 is quite heavilly bottlenecked by the 3770k and I like that the 1060 doesn't turn on the fans until it's under load. My biggest needs for the machine are silence so I can use condenser microphones in the same room as it, and long term stability as the most important use is for making music - my current build doesn't come close to its limits for that and from what I can tell even a modern i3 would significantly outperform the 3770k I have atm. If I can avoid replacing my PSU I'd like to - are we still on 24+4 pin power and 8 pin CPU power?
I need lots of SATA ports.
Thanks for the help
Thanks for the help
