Considering a new card...decisions decisions!
1 Jul 2007
Various
I'm currently running: C2D E4500, 2GB PC6400 Geil Black Dragon, Radeon 3850, Gigabyte P35C-DS3R, Corsair HX520.
I have about £150-£200 (at the absolute most) to spend, and am considering an upgrade. Effectively, I see my choices as coming down to a 4870 1GB or GTX260, with 4 brand spanking new gigs of RAM, or a 4890 alone.
I know that my CPU is dated, but it still hits 3Ghz, and I'd argue that a GPU and RAM is more pressing.
Personally, I'm leaning towards the 4870 and 4GB Kinston DDR-8500 RAM. What do you lot think?
you on Xp or vista if vista I would get the HD4870 and the RAM it needys it :P (the ram I meant unless you can some how afford to get the 90 with the RAM somehow)
I managed to get corsiar 6400 4Gb set RAM and a XFX HD4890 for *just* under £200 delivery charges will put it over through thats how tight it was :(
Well seeing as you have free delivery you can get the following for under £200 (just)
Your basket
Product Name Qty Price Line Total
XFX ATI Radeon HD 4890 1GB GDDR5 PCI-Express Graphics Card - Inc. Tom Clancy's H.A.W.X £159.99
(£139.12) £159.99
(£139.12)
Kingston HyperX 4GB (2x2GB) DDR2 6400C4 800MHz Dual Channel (KHX6400D2LLK2/4G) £35.98
(£31.29) £35.98
(£31.29)
Sub Total : £170.41
Shipping cost based on delivery to Home Address, BS3 3DS with:
FREE SHIPPING (DPD Next Day)
(This can be changed during checkout) Shipping : FREE
VAT is being charged at 15.00% VAT : £25.56
Total : £195.97
Depending on your res that would work, though if it's under 1680*1050 maybe go with the 4870, even then though the 4870 is only £20 cheaper, so I personaly would get the 4890 anyway.
I'm currently running at 1400x900 - was strongly considering upgrading my monitor to the NEC 24" that gets rave reviews, but had a couple of other things I needed to buy (a new cricket bat was the most pressing!) Meant that I decided to go for a smallish upgrade along with a couple of other purchases.
In a nutshell, that means that I may consider upgrading my monitor at some point by this time next year, but it won't be imminent!!!
well it would be the 90 than, as you would propely rip out the HD4870 anyway
In that case go with the 4890, as I've said it's only £20 more and will last you a dcent amount of time and be brilliant for a 24" later on.
