Considering a Sandybridge upgrade
26 Feb 2009
Norn Iron
Hi guys,
I'm having serious issues with my motherboard at the minute and considering an upgrade as an easy fix.
I'd basically only need a new CPU and mobo. I assume I can use the same RAM from my current system even though it's not rated for 1.5V? Or do I need new RAM also?
Furthermore can I use my current cooler? Are they different to the 1156 connections? It's a Zalman CPNS something something.
The motherbaord must support crossfire (8x8x) as I have 2 5770s currently.
Can some kind folks spec my a decent bundle? I am also considering going 8GB RAM as it's so cheap these days.
That looks good to me. Any advice on whether my current ram and cooler will work with that mobo?
I assume this board will be good for ocerclocking? It sure sounds it but I hope it's not all talk!
yeah the MSI boards are great for Oc ive had a mess about with mine when first built just to see what i can get, i always run at stock for a year then Oc when i feel i need more power :)
I already have a very decent cooler so have no need for another :-). The only other difference I can see in the more expensive board is it has a few extra sata ports?
As for going z68 I think it would be totally wasted on me as I already use a 60gb SSD anyway :-). Thanks for the advice all. No doubt you'll be seeing me in the overclocking subforums soon enough!
