Considering a system
30 Dec 2011
I have a monitor and peripherals etc.
So looking to purchase a good gaming system, with a budget of around £1000 upwards. I play WoW and hopefully looking to play GW2 and SWTOR
Just want some opinions, anything would be appreciated.
I was considering this below with the 7970, but can you change some parts that are not available, like the case for instance.
http://overclockers.co.uk/showproduc...odid=FS-237-OE
Would I save a lot if i was to build something like the above link myself. By myself i would probably ask my uncle cause im a bit of a novice when it comes to putting computer together etc. =p
Your link doesn't work.
You can change the case on these pre-builds to what you like (assuming everything fits inside;)) just ask in the customer services section.
Well I have a 6950, on WoW, org or sw depends on how populated your server is, 10 and 25 man Sit above 30 fps on most encounters with everything on ultra.
