Considering an SLI Upgrade; Need a little advice
13 May 2009
Howdy howdy.
I've been considering giving myself an upgrade lately. I'm currently using a gtx 260 and the performance is fantastic. Still, nothing wrong with getting even etter performance :P
the only problem I've faced so far concerning upgrading is the cards themselves.
My current GTX is this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-131-XF&utm_source=froogle
The only one of the same brand and range I can seem to find is this:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-130-XF&utm_source=froogle
I know mixing cards can cause problems, and the differences are pretty minimal between these two. The only problem is that the one I have is factory overclocked.
Would pairing these cards be a problem?
Also, if there was the possibility of pairing my card with another GTX of a different brand, are there any recommendations?
you can pair with any 260GTX - just try and make sure they are both clocked to the same levels tho so you don't get jerky performance.
